water pump or crossover ?
Charter Member #1171
Why change from recirc pump to crossover,,, pro's con's ,,,, does it matter more for carb or injected? The subject came up, I just wanted more input,,,, merc puts pumps the 502 mag,.,,,, but a 500 gets a crossover,,, why !!!????
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Ginger or Mary Ann?
Crossovers can mostly be found on blower motors, BUT, even Merc puts water cir pumps on their blower motors: SC525, SC575, SC600, & SC800
right,,, but not the 500hp !!! thats what I don't get,,, what makes it right for one motor and not another,,, I have heard a crossover is better provided you keep a thermostat, I have also heard you need the pump,.!!!!! ARGH !!!!
![Confused](/forums/images/smilies/confused.gif)
Ginger or Mary Ann?
Might recheck your source.
The crossover allows for better cooling, which is a must for a blower motors in order to help prevent detonation. Yet Merc must feel pretty confident in the w/p capabilities on their blower motors and, yes, the HP 500's.
I agree, a t-stat is a must. You must have to have the correct plumbing if you do use a crossover with a stat.
My opinion is that on a stock nat asp motor, the stock setup works great and is very hard to beat.
Jerry
Jerry
Charter Member #737
I like the crossover which is what I used one less thing to break.
Thanks guys,,,, OK Paul,, now does this answer your question !!!!!!!
Can't stand being wrong can ya !!!! Hey,,, look at it this way,,, I just saved you $200 !!!!
Why I did not need a X over 454 mag no blower!!Someone said and I thought it would be less trouble-right.Installed x over,now the water pressure is to high,I thought and weilded pressure valve on x over, great water pressure is right on. Now water temp. is not stable enought for me,I thought and now I am trying to get y pipe made up to pre heat water from exhaust. Not much left now but I think I thought to much and did not know enough.James
![Cool](/forums/images/smilies/cool.gif)
