New Mobil 1 Racing Oils 0w20 & 0w30
Dominator Racing 15w-50 $132.65 plus shipping (12 quarts)
http://www.amsoil.com/storefront/rd50.aspx
Dominator Racing 10w-30 $127.80 plus shipping (12 quarts)
http://www.amsoil.com/storefront/rd30.aspx
Dominator Racing 5w-20 $127.00 plus shipping (12 quarts)
http://www.amsoil.com/storefront/rd20.aspx
Signature Series 0w-30 $124.55 plus shipping (12 quarts)
http://www.amsoil.com/storefront/sso.aspx
That Mobil product is a real good product, however, its not much better if you compare the stats, especially for the price.
Or am I missing something?
I would say 6000 + RPM , and i change it after every race ( 1 + hour or so )
Tricked out engine is like a 12:1 compression that turns 7500+ RPM !!! N/A !!!![EEK!](/forums/images/smilies/eek.gif)
At least thats what i have been told !?
Also the Penzoil Racing 25 W -50 is a very good oil !!!
Valvoline Racing 20 W-50 is good too ,both are non synthetic which i think is what u need on a roller cam top end ,,because the synthetic is too slick the rollers actually slide instead of rolling !!
i'm no oil expert, but from what I know, the only advantage a 0-xx weight oil has is in a VERY slight hp gain. actual durability and life of the oil will always be better in the higher weight oil. That's why we run them. Even with the 15w50, I find I need to change every 25 hrs or so. I can't imagine how often I'd have to change the 0-xx. And all for half a hp or so???
If you ran tighter clearances, a 0w30 might work.
Keep the 0w30 in your car, in Minnesota in January.
As far as durability goes, the 0w30 would last the 25 or so hours but if the is any viscosity breakdown, you will have something less than a 30 at 210F.
The durability relates to the base stock of the fluid.
Mobil 1 is a PAO and they are pretty stout.
Ken
Better let the Cup guys know that they are really exceeding the limits of their oil, or the Indy guys.
Valvoline Racing 20 W-50 is good too ,both are non synthetic which i think is what u need on a roller cam top end ,,because the synthetic is too slick the rollers actually slide instead of rolling !!![EEK!](/forums/images/smilies/eek.gif)
Harley tried to say the reason cam bearings were going bad is because people were using synthetic oils and the rollers were sliding, causing flat spots and taking out the bearing.
IF THE ROLLER IS SLIDING, IT IS SLIDING ON A FILM OF OIL!!
How will it wear?
Notice how when HD came out with a synthetic the reason went away.
Ken
The synthetics are no more slippery than petroleum oil.
How will it wear?
Ken
How will it wear?
Ken
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
You tell 'em. I'm sicking of hearing that reasoning too. It makes no sense.
