stock exhaust to gil dry system
Just put together a 496 stroker and picked up some gil manifolds with dry pipes i have 4 lines coming out of t stat housing is there any way to plumb the system with buying 2 60 doller y fittings , and Ive seen the manifolds plumbed 2 different ways first both hoses merge and go to bottom of manifold then jumper to riser , 2nd 1 hose to bottom of manifold and other merges with jumper which way would be better ?
also i ran into 1 other problem the nipple at the end of the pipe closest to exit is the water dump correct? i had to cut it off to get pipe through transom then heli arced it shut can i just cut another hole and put that fitting somewhere else? close to the end of the pipe
3/4 NPT on the part that goes into the manifold and hose nipple on the other 2 ends. That is a factory Merc part. I actually just sold the set I had to Fixxer22. I'm not sure if he ended up using them. You could PM him. They are outrageously priced for new ones. I'm sure you could have a pair custom made also for a lot less.
Email Ken at http://www.offshorenortheast.com/
