left/right rotation
stupid question
which is which, looking at front of engine.
mine rotates clockwise looking from cockpit.
is that right hand.
is the right front cylinder [looking from the cockpit ]
# 1 and distributor cap order and firing order the same
regardless of rotation
is that right hand.
But /or and yes,,,,,,that cylinder is #1
That should be standard rotation. Yes from the front of the engine, the number one cylinder is on the right front. The order should be 1-8-4-3-6-5-7-2. Make sure your start your wiring with the number one piston up and both valves closed. Otherwise you will be 180 out and it will not run well.
