496 No Start After A Hot Soak
thought i had a fuel pressure problem,,,pressure is good on the gage,,,heres what happened started cold engines and went for a half hour run all was good,,,stop for a ten min,swin,and the port engine wont start,,,starter cranks,,,and i can smell fuel,,,so has anybody had a hard time getting there 496efi engine started after a run,,,and not letting it cool down,,,maybe crank or cam sensor iam thinking???
has raylar kits on it,,,other engines run fine,,,the engine iam having trouble with has a hard time starting after a hot soak,,if it starts at all,,,would the layard be causing one engine to run and the other one not two,,,boat has one layard
THIS ACTS JUST LIKE VAPOR LOCK,,,i thought they had it fixed with the cool fuel(both pumps in the box,,with water running thru to keep the fuel cool)could the water flow be blocked???
i also want to know why one engine has steam coming off the tailpipes,,,and other engine does not,,,both engines are at the same temp,,,could the raw water pump system,,have blockage,,,and if there is blockage,,,would the cause the fuel to vaporize,because the cool fuel 3 is not getting any water,,thanks for everybody,s input
Not the same motors, but, I have 2001 502 efi's with cool fuel, and recently had a vapor lock issue. Began in one motor (port side) after sitting around for 30 min to 1 hour (heat soke). It would start fine, then bog down and hiss, then die. After 5 min or so it would start back up and run fine. The next weekend, both motors died after heat soke time. Again, these are cool fuel motors. The next weekend ran most of the gas out of it, fueled it back up, and problem solved. The gas had been in the tank for approx 3-4 months. Turns out that boiling point of some fuels drop significantly after 30 days, and continues to deteriorate after that.
