Hi Rev Hydraulic Lifters & 20w50 Oil
For clarification,
Are oil restriction plugs recommended when using lifter bore bushings with hydraulic lifters ?
Regardless of block brand, is the lifter bore bushing length critical ? Is the critical length the same for any lifter or is there a guide line length specific to lifter used?
Jessel and others claim to have a proprietary alloy bushing. Do you agree with those claims ?
What is the best way to create a centered and plumb bushing bore ? Then, hone installed bushing to square, ID and centered ?
What is the price range for initially installing lifter bore bushings ? Price range to replace bushings during a refresh ?
MER, Thanks for this VERY important thread !
Beak botr
I will chime in here on the RL-932's.
I have dart block and was running Crowder Hydraulic Rollers without thermostat and had to put pre-lube pump on engine to keep lifters pumped up. Started with 20-50w synthetic Amsoil, but with cold engine had oil pressures of 80 psi + after running (100 + stone cold). Switched to 10-40w and got pressure to 60 psi hot. Never could build heat in engine (540 NA), so installed 120 degree thermostat and saw improvement in oil temp, from 180-200 to 230. When at 230 with gibson down turns and hatch open sounded like all lifters were very loose, about to have failure. I did not even want to run the engine again after that one trip!
Installed Bob's RL-932's (PBM) and running 10-40w NO NOISE at 230 degrees!!!!!! No Noise at cold start either! 10 Hours so far but all low RPM (under 3500).
Got the note about the clearance check and as best as I can measure with snap gage is about the .0015, have to believe that the Crowders were on the small side of .841 and could have been most of the problem with them.
Thanks Bob, I call soon to get my other set!!!
For clarification,
Thanks Mark, Have you seen blocks with lifter bores that are not centered, properly located and/or not square with the cam journals? Were any of those problems to exist, would lifter bore machining/ bushings be the solution ? When those problems/conditions exist, what further problems may be expected ? Is it difficult to determine if the lifter bores are in tolerance without using the BHJ lifter true fixture, cnc block mill or a similar expensive tool ? It has been said, the machinist must be proficent to properly machine and install lifter bore bushings...COMMENT ?
In your opinion, is harmonic vibration related to out of tolerance lifter bores ?
In your opinion, is harmonic vibration related to out of tolerad nce lifter bores ?
If you have more questions concerning the valve train, maybe we can get RM BUILDER in here for his input on this, I leave cam and valve spring recommendations up to him, maybe he can give his input on causes to lifter bore out of tolerances, and harmonics. Thanks for the questions.
Here's a question for you. What is mechanical background? I know these guestions are not from the average weekend boater. Mark
Mark, Thanks for taking the time to explain how important and sometimes complicated it can be creating a good dependable valve train.
Hopefully, the honesty, integrity, humility and knowledge you've just shown will be rewarded in the form of business from those who may have read your thread.
Interesting, by comparison to your honorable character, another visible engine builder took exception to dumb questions and chastised, probably me.
In this day and time it is becoming difficult to find loyalty.
He's all yours GUY'S....Give him some business, Mark can handle it !!!
While I don't know Mark, I'm impressed with his response. Therefore, I am of the opinion his thread should stick around to allow everyone interested, the opportunity to read his information.
Mark,my lifters were not the hi rev version as they were just not ready yet in the spring of 07 when I was finishing my motor. As far as my lifter clearence,I was using a new,never ran dart block that I had sent out to be prepped. I was waiting for the hi rev marine hd morel lifters right until we got a week from my Dyno date,the lifters just weren't ready. At the last minute RM builder found me a set of the std bbc lifters which I receieved 3 days before dyno time. I had already assembled the motor as far as I could and when I went to put the lifters in I found they were at .001-.0012 clearence which I considered to be just a little tighter then I'd like to see BUT tearing motor back down and honing lifter bores would have moved everything back to the point motor would have never made it into the boat that season as my schedule was very inflexible at the time so I ran them. This motor does have excessive oil pressure,it will see up to 100 psi cold, I never had that problem with the merlin block and it's sloppy clearences,Smitty
