Shell Rotella T oil YES OR NO?
needed to change the oil in my 502 roller motor in a hurry no mercruiser oil around... went to Walmart bought 3 gallons of Rottella T 15w-40 for $9.00 a gallon.Is this stuff good to keep or should I suck it out and put in mercs 25w-40 for $26.00 a gallon
It is great oil. I used it for break in and then next 10 hrs before synthetic switchover.
I would use it. I use it in everything. Our CAT motors get nothing but that oil and we abuse the chit out of em and change it every 15k. They are used 10xs harder than you will ever use your motor.
I use it in my supercharged engines, roller cams. Real good oil. I'd only worry about not running the syn if you oil temps go above 250f on a hard run. Syn take high temps better than dino oils.
