oil temp too hot any suggestions?
#61
I have read that also but it did cool my other motor so? If the water leak doesnt fix it I will put a new\bigger nin chromed cooler on it next.
#62
SORE MEMBER
1 Post
i checked out that possibility, the cooler does radiate heat, and it's possible that chrome may affect radiated heat by that percentage, however the water to oil interface through the brass or coppernickel tubes is the primary cooling method and radiated heat is a fairly small percentage of it.
#64
SORE MEMBER
1 Post
don't see how you could get 190 oil on the trailer
#65
Geronimo36
#66
no I am not. the shop that put the motor in broke the sender that was in the pan so they replaced it. the line out of the cooler to the oil pan isn't that hot. I can hold it in my hand and its a braided line. the line from the pan to the oil filter is too hold to hold so I know that the cooler is doing something. the cooler is also pretty hot to the touch but I am thinking it should be if its working? I am going to order a new sender and try that then I guess if that doesn't work I will try a new cooler. Like I said guys I have been around and owned race cars for 20 years and even owned a race fab shop but this thing is wearing me out lol!!!! My thinking is that if the bearing tolerances were too tight it would at least cool off after letting it idle? would running a thermostat or restrictor in the water neck increase water psi? I have a crossover with a bypass and no restrictor or t stat. the water temp never gets over 150 idling on the trailer.
#67
SORE MEMBER
1 Post
#69
#70
