Help with Carb Adjustment
1 Post
I ran it last weekend and after getting to the beach the choke was all the way closed. How do I fix this? I also noticed what looked to be some water droplets inside the carb. I have already replaced several fuel/water seperators and pumped the fuel tank empty. Any ideas?
A webber carb has a electric choke and the power wire may have came off thats why its stuck closed but it should be idleing chitty...a q jet has a mechanical choke that works off of he reastat from the port that heats the intake..that could be bad or the choke lever couls have came off..
My Merc Weber carb used reastat also.
You do not need a new carb. You just need to fix the choke. You won't see any noticeable performance gains with a new carb.
Does your carb use an electric choke or a spring reastat??? a new electric choke kit is available from merc for about $90.
http://www.mercruiserparts.com/Show_...OR+%28WEBER%29
I live in Indiana.
When I was out last weekend the choke seemed to be working correctly. It was open when I got to the beach, but after sitting all day it was still hard to start.
I am trying to figure out what kind it is. It has a W stamped on the top so I would assume that it is a Weber, but the only numbers I see on the carb is 8867. I cant seem to find any info if these are the right numbers. It does look like the carb in Griff's link.
I live in Indiana.
I would bet that the choke closed while you were on the beach. Just for the heck of it, use a zip tie or wire and hold it open for a day. It may be just a little harder to start cold, but see if it starts easily when its already been running and warmed up.
