Can I get away with 91 Octane with a 525SC
I have run 89 for 6 seasons when had the 525SC's... Just make sure your timing is set at no more than 35*@4500rpms.
Don't waste your time on an innercooler.
I'm 99% sure you will be fine running the 91 octane on a stock 525SC. I ran 92 octane in mine and had the boost cranked up to almost 8# with no chiller. Never any problems at all and it had over 400hrs on it. Stock boost on a 525SC is 5.5#. Maybe dial the timing back 2 degrees to be 100% safe, but I highly doubt you really need to.
BTW, full advance on the timing does not come in until about 4500rpms.
running them rich doesn't really help in the detonation though. you still need sufficient octane to with stand the combination of heat and pressure.
Running a little rich will help keep cylinder temps down and help avoid detonation. They are plenty rich from Merc and have #98 jets squared. I had ran mine up to about 5 mins at WOT, buit mostly only 2-3 mins. The water temp would creep up about 5-10* and I would back off.
Mississippi math
say you burn 300 gallons a month , the differance in gas price 91 to 93 at $2.75 is usally 10 cents,thats $30 dollars a month you save.
But being thats all ya have there, like Biggus says,Ive never liked running timming real low,exhaust temps on pump gas
thats my $30.00 worthGoodluck
Rob
Rob
Mississippi math
Rob
Rob
Unfortunately we can't even get 93 at the pumps where I boat in SOCAL. 91 is tops. I would gladly spend the extra 30 bucks for the added protection.
Darrell.
