Billet 525 EFI pulleys
I've not had any experience with these guys, but ran across this:
http://www.bullet.on.ca/part_upgrade.html
Good luck.
Good luck.
1 Post
or you can try matching somthing from thease guys...
http://www.billetspecialties.com/ite...id=283&pid=704
CP Performance has the nicest setup. They are not cheap, but anything that is that nice won't be cheap. The thing I like the best is that they use a mandrel on the p/s pump and sea pump. If you just press an aluminum pulley on a steel shaft, eventually it will wear out the aluminum pulley and it will become loose on the shaft. They use a steel mandrel that presses on the shaft and then the pulley bolts to the mandrel. I have used them several times and have been extremely pleased with no problems. I can also get them for you. Give me a call if I can help.
Eddie
Eddie
Eddie
Eddie
thanks
