Cam duration vs RPMs
Was thinking about swapping out my cam this winter. Currently running the GM 454HO roller cam(I210/E230). Does the intake duration, exhaust duration or the differrence between the two effect the RPM range. I assume its the intake but I've seen dynos where they run this same cam to 5400 RPMs?
What is the basic RPM range for a 210,218 or 224 cam?
Call RMbuilder, AKA Bob Mandera, AKA Marine Kinetics, he is a cam expert. He will talk your ear off about cam specs. I told him what I wanted and he made it work. Typically higher duration means higher RPM range, higher lift is more power within that range. But there is way more to it than that.
Yeah, He is the man. Hate to bug him unless I'm ready to pull the trigger. Just thinking out loud now, trying to get a better basic understanding of duration rpm ranges.
good luck and have fun serving some of the cam sites. there is endless amount of info on the internet about camshafts and you can learn a lot.
You need to have good exhaust when you start going to bigger cams. Both to prevent reversion and to let the engine breath.
Lift is 511/540 114lsa
I think this cam is best fitted for the Rec heads it was designed for & not ideal for my ported vortec heads.
My exhaust is 496 take offs w/ Corsa Q&Q. Wouldn't the 236 exhaust duration on the 731 cam be a reversion issue w/ my exhaust?
I doubt the 731 or similar can be used with 496 exhaust and Q&Q without reversion. The 731 also has 112 lob sep. I would say you are close to your limits. You could probably increase intake lift and duration up to about 226, but I would try and keep the lobe sep at 114.
Talk to Bob M/rmbuilder when you are ready to do the upgrades.
As a rule most aftermarket cams are not suitable for stock exhaust. You need long risers to avoid reversion. I had a flat tappet hyd Crane with about 230 duration and I got excessive moisure in the engine with stock exhaust. I now have the EMI thunders with long risers.
