Distributor gear question 454 to 502.
The gear is black, a cast gear is black, that is one of the topics Bob was trying to explain to me. Sometime he gets to talking and and it goes over my head.
Sleep well tonight
If I have time I will put to different ones side by side and post a pic.
The man has answered.
Sleep well tonight
Sleep well tonight
You can clearly see the difference between the two cams.
Like Griff said earlier you are making something out of nothing.
I to was concerned like yourself, but I have two new engines at risk and will end up in divorce court if I mess it up
I thought you said that the 502 cam was a one piece cam, so the gear on mine and your cam is black in color? How is the cam steel and the gear cast? Basicly bob told me that if my cam has a pressed on cast gear that has been hardened then i also need a hardened gear in the distrib.
Anyone have the part numbers for the gm one in the base 502.
I know im going crazy over this, just want to fully undersatnd it. lots of grey area and 100 of post not confirming anything all over the internet.
Thanks for having patients with me!!
In case someone digs this up in the future.
Both cams are one piece.
one is a billet steel Roller the other Cast Steel flat tappet.
You can press a cast gear onto a billet steel cam to retain the original distributer gear used on a flat tappet cam.
Someone must have pulled gen 6 mag 454/502 out of a stock merc motor..
Just a side note for anyone reading this. DO NOT put a dist. gear that has been run on one cam onto another cam, even if the cam is new. You are asking for trouble. Go ahead, ask me how I know. Once a gear has been run on a cam, it should not be used on another cam. Replace the gear with a new one. You can keep the gear with the old cam so if the cam ever gets reused, then you can reuse the dist gear.
In your case Ballon, you need gear # 10456413.
Eddie
Eddie
Learn something new every day, even at 48 years young.
I would be scared to count how many cams I have changed and ran the same gear. I am surprised Bob M. never mentioned it, because that is the reason I wanted have always ordered cast gears to use the same gear on my old distr...
Eddie
Eddie
Trust me i wish i could just toss on the GM gear and be done already!!
