Distributor gear question 454 to 502.
#31
Eddie I have the GM Melonized gear, and tried to install it, but its was so tight the distributor wouldn't even turn. If I remove the stock shim then its good, but I cant run the distributor with out that shim.....What should the shaft end play be set at for a minimum. I ended up puting the stock gear back on and orderd a brand new merc gear to put on this weekend. How come my old motor which was a 330hp 454 with a roller cam can run the stock Thunderbolt V merc gear and the 502 gm base can't. Is the 330hp cam non magnum roller cam not a one piece billet like the 502 cam.??
Eddie
#32
Learn something new every day, even at 48 years young.
I would be scared to count how many cams I have changed and ran the same gear. I am surprised Bob M. never mentioned it, because that is the reason I wanted have always ordered cast gears to use the same gear on my old distr...
#33
Obviously, a used gear possibly can live on a new cam. Plenty people have done it. However, I can not tell you how many I have seen them wipe out the gear in 2 hours or less. It has happened to me as well in the past. I could maybe attribute others to someone doing something wrong, but I know I didn't do anything wrong. I loaded them up with the same Moly lube I always use on new gears, and they still got wiped out. Learned it the hard way. You may be able to get away with it, but I will never take that chance again. It is not worth having to take an engine apart over a $50 gear.
Eddie
Eddie
