177 Wieand Blower fluid
I've used Amsoil marine gear lube in
my 256's the last 5 years.
http://www.blowerdriveservice.com/faq.php
Can I use a synthetic oil?
Only use a heavy duty 90 weight gear oil lubrication which is a non-detergent oil and basically no synthetics. They are too thin.
If the oil is too thin when it is new, you have chosen the wrong viscosity.
If the oil is too thin when used, it has sheared from too long of use, or perhaps fuel dilution, etc.
It is not too thin because it is a synthetic.
Ken
