496 crankshaft balancer bolt size
Replacing the crankshaft pulley and the stainless allen bolts broke off in the balancer. No room to drill out the bolts in the boat so need to remove the balancer. Anyone know the socket size (metric)needed to remove the balancer bolt?
Thanks,
Keith
Thanks,
Keith
496 Ho
hi i have a 28 foot pantera twin 496 ho can anyone tell me wot oil presure should be , these are 2001 motors i have started the motors and got 42 psi at idle aprox cold reved the motors 2500rpm and psi stayed the same this was done with boat on trailer conected to a hose i have electric gaffrig gauges . this is a new boat for me and only just got it back to the UK two weeks ago like to be sure everything is ok befor i put it in the water and give it some stick
