Bravo 1 4 blade stainless prop question
Friend of mine has a used Bravo 1 four blade stainless prop he want to sell to me. It has about 2 inches broken off one of the blades.How much is a 4 blade prop worth with one broken blade? How much to have it repaired. thanks
It's not worth much on top of the fact that if your boat only has a 454 in it theprop better be a 22 pitch or so other wise you will never pull it unless your motor is modified. Your going to have to get it repaired,figure 200-300 dollars for that then is it even the right prop? Smitty
Tell him you will give him $.50cents, the only thing you can do is sell it for scrap metal. If it could be fixed, he probably would have aready fixed it.
Friend just bought a house. The prop was in basement. You guys know more than me. I will pass on it. Let see if he gives it to me. . Thanks again. Mike.
