Steering
Pirate of the Chesapeake
Hey guys! if I have a complete hyd external steering,not a add on where you keep the steering cable.Do I have to use a power steering pump.I don't want to run it if I can do without it.Single engine small block 20'boat it only weighs 2800# and could use some feel in the steering.If so is there a diagram somewhere on plumbing it. Thanks JOHN SR
you need the pump,it would be tough to turn the wheel without it.
1 Post
http://ww2.seastarsteering.com/SPA/spa.htm
Depends on the helm unit you have. The Eaton Char-lynn are designed to work with a P/S pump. Capilano (variable displacement) and Hynautic (fixed displacement) do not use one. The teleflex web site has some good information on it on plumbing if you search around enough.
Randy
Randy
I have a charlynn helm with the four hoses,it's made to use with a power steering pump.My steering ram is a imco .Can I go to a hynautic or teliflex helm and use it so I don't have to use a pump,and the electric's are way to much money.Thanks JOHN
Here is a spreadsheet I came up with to model the steering system on my mistress. You'll need to figure out what kind of helm displacement you'll need to have a reasonable lock-to-lock.
I found a used hynautic setup and am going full manual, no PS. I figure its one less thing to break.
Manual vs Power
Manual vs Power
Yes you can use a teleflex or hynautic helm. The problem I had with my hynautic system is I have 2 rams and the lock to lock is around 8 turns. not enough cu.in./revolution. I am now going to a charlynn system with the 4 hoses and a power steering pump. With a single ram I wouldn't have minded the hynautic system. You need a pressure can/reservoir with the hynautic system, and with the teleflex system you just need the helm. I just sold a tilt teleflex helm, I still have a Hynautic H21 that I was using.
