496HO Circulation Pump.
Forum Regulator
I think mine is letting go. Engine heats up on the hose, and the antifreeze is darker than the other engine that is running fine.
What's the difference between a Mercury 496HO circulation pump for $425 dollars...
...and a 496 Chevrolet Truck circulation pump for $186 dollars?
They both only see Dexcool; as it's closed cooling on the boat.
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
The Merc branded circ pump is not just more money. In this particular case, the Merc pump has a completely different sized impeller and it's made of brass.
The Merc pump moves more volume. I would not recommend using the chevy pump for 239 cheaper.
Effectively it's a bigger pump with the exact same housing and bolt pattern. I went down the same road as you. I took them apart and inspected.
I decided to go with the Merc one. I won't swear that you can't get away with using the cheaper one but closed cooled engines typically run hotter than open cooled. I did not wanna chance having that cheaper pump that might just "barely" keep up...
Take your old one apart and compare if possible. You'll see the difference.
Forum Regulator
Thanks guys. I don't mind paying Mercury money for the right part. My question was more out of convenience. I can find a truck part in about 30 minutes if I need one. I would have to dig/order a Mercury part and have it shipped in.
I thought I had one going south on my boat, but I took it out for a shakedown cruise today, and all is well.
