crossover hoses
hp500 carb motors with stock gill exhaust, can i reuse the same hoses with a cross over as i did with stock circ pump or do i need to get different hoses and if so where and what are they. Thanks Rick
If you can use them without having to ad to them I would go ahead and use them. Does your Xover have the same size water outlets as the stock set up. Most of them do however I probably haven't seen them all either. I've reused mine on my CMI's and it seems like the Gils enter about the same place. How did you make out with your cam degreeing? Did you end up a A4?
Rick,
