Average build time for engine?
Don't worry about Steve, he spends too much time talking to his dog and probably doesn't have enough interaction with humans.. He was trying his best to give you good advice.
As far as build time, bolting it together is the least time consuming part. If you trust your machinist enough to not check any of the clearances... and the pistons are on the rods already then it should take two to three hours to bolt the short together. But there are a number of little things that can still bite you and I see them all the time. Pre-gapped rings are sometimes too tight, an improperly installed spiro lock can destroy your engine, piston rings not installed properly can cause problems, using the wrong ring compressor can cause the rings to break, the wrong style/quality of torque wrench can vary greatly on stuff like rod bolts, etc.. etc..
If you are going to do it, make sure everything is as clean as possible, get a paint marker to keep track of everything that has been final torqued, check your work, and go slow. Feel free to give me a call if you want help on the valve train geo. I can probably explain it easier the it is written. Good luck, Alex
604 315 0570
604 315 0570
Yes! I had Dave build the short block and I'm going to finish the top half.... I picked up the engine today, now it's time for me to get to work.
For the record it was 8 hours to install the crank, hang the pistons on the rods, install pistons, install and degree cam. No clearancing needed the engine is a destroked 454.
What is the average build time for a bbc short block engine. There is no clearancing needed as the stroke is stock? Also what is the average time to install the heads and valvetrain when custom pushrods are needed... I'm trying to decide if I want my builder to install the top end but I've not been able to get in touch with him.. I'm just trying to ballpark these costs.
Thanks in advance!
Thanks in advance!
I had mine ( 509 ) rebuild in 24 hours complete but the guy busted his a$$ !!!!!!!!!
