What all would take out a coupler?
keep me posted as well cause nobody has an answer for me , i really dont feel like doing this a third time! what coupler part number did you install and on what drive and motor, mine is a XR on a 525efi. both times it happened to me i just finished passing a big cruisers wake but my mechanic swears everything is tight and nothing is moving, but my top gears are finished,need to be rebuit
Our problems are a little different as my gears still look brand new. If yours are blue that would be a sign of excessive heat. So i would guess there is something wrong inside your drive. From what I can tell most of my internals don't show any problems that would cause teh drive to lock up.
I will keep you posted though as to what I find out.
Mine is a 600SC connected to a XR drive.
Is this the post your talking about. This is what happen to me.
http://www.offshoreonly.com/forums/g...p-coupler.html
OK, long shot, but I seem to recall reading something about HP couplers requiring somewhat of a different process over stock when putting the motors in. Wish I could remember the thread. That is the only thing I haven't seen mentioned already. Hope that helps, I'm out of suggestions.
Yes
Geronimo36
Are you running the HP Couplers with steel splines and snout or the standard coupler with aluminum splines? If it's the rubber maybe you just got a bad coupler. Seem's odd to me, I'd have to see it in-person.
I blew a coupler once in my 36' and the only reason that happen is because I blew a drive and it locked up but that was before I got the BMax drives. Matter of fact, the coupler didn't actually blow, I ran it the following weekend and replaced it the weekend after that because the rubber was starting to fall out. I'm running the HP couplers with steel splines on 800+ hp..
Have you checked the gimbal rings for excessive wear/play?
Mine had the steel splines. The rubber is what exploded & took out the rear mount and wye pipe. Lucky it happened close to shore so we could paddle in before sinking.
