Hours till oil change?
How many hours do you guys allow before changing the oil? I allways pull the stick before and after use but whould like some input. Motor is a 454 MAG Whippled.
I used to run 50 hrs between chnages. (Stock SBC, but runs pretty hard (lotta wakeboarding). But one time after 35hrs I got an oil analysis and it said the oil was pretty used up so now I try to do it every 25 or so.
Well, I cant give you a before and after cuz I bought the boat complete as is. Its a strong runner, the motor was fresh when the whipple went on and the only thing that has been modified is the heads have been worked with larger Enkinel valves and some stiffer springs then bench flowed. It has a few things I would like to get sorted out, it runs a tad rich and can die and semi flood when loading on the trailer or beaching. It was dynoed at 535HP and 710TQ and runs super cool, around 105 cruising and 120 on long pulls. I want to put a set of headers on to lean it a tad, whipple said it would help alot. My Crown is a sleeper for sure, no one expects a 70+ but I dont want to invest to much as I am going to buy a real boat in a year or two.
