502mpi questions
502mpi questions
I am having a issue engine will not start when hot. It has been rebuilt due to previous owner overheated it. The issue is when its cold it has great compression 125-130psi when its warm it has a max of 60psi. I can get it to run but cranks forever. I tested it both dry and with oil in cylinders no change in the numbers. The engine has 20hrs on it. anyone have seen this before?
thanks for advice
thanks for advice
I believe normal compression on a stock 502 is about 150psi. The engine will NOT start with only 60 psi compression. It takes a min. of about 100 psi compression for a cylinder to fire. A leakdown test would be in order at this time to tell if the engine has a mechanical problem and would tell you why your compression is low.
