Tranny Fluid for a TRS?
Well I crawled in there last night stood on my head and didn't see any drain hole or plug!?!? I did see where the line went out the bottom then to the cooler then back to the tranny through a fitting in the top of the tranny. I Know I can pump out the fluid, but will I get all the fluid out of the cooler also? I dought it, so I guess I will just have to change it again, here pretty soon??? What do you guy's think?
BTW, it's a Borg/Warner Tranny! Is that good or Bad?
What do you guy's think? just suck out the tranny?
Man, that sounds bad!! Hopefully you guy's here on the tech. side aren't as dirty minded and Troutly and the rest of the bunch!
