2001 7.4 Horizon timing question
Here is a link where this was discussed at length, with pictures.
http://www.offshoreonly.com/forums/d...an-1-00-a.html
JIM H
It is actually easier to bring it up to around 1500 rpm or so. This will help stabilize the timing and make it easier to set. It will still jump around just a bit at idle. If it won't take any throttle or kills as soon as you put in the jumper wire (paperclip), then the timing is to low. Advance it a little and try again.
Eddie
Eddie
