Transmission Help Please!!!
Offshoreonly Advertiser
We take a few thou off the key where it rides in the gear. I think the shaft twists, skews the key and BAM - splits the gear. We are also able to get an extra friction plate in them.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
[QUOTE]Originally posted by mfb357
[B]If those trannys are Borg Warners you need to watch the fluid level. They are very sensitive to low fluid and will burn out.
I checked mine last night and one is a little low, but the other is WAY over full!?!?! What's up with that? You think the last guy just overfilled it? I hope! Since they are so sensitive to the level, would being to full hurt anything?
![Confused](/forums/images/smilies/confused.gif)
I have been told that overfilling the trannys slightly will not hurt them. Hopefully I will know what happened to mine by the end of the day and I will post.
