2 batteries?
I have a 20' wellcraft with a single battery , do I need a dual batt setup? I only turn on the radio for an hour max with out the motor running
Charter Member #232
Well that depends. You are probably ok with just one. If you see your boat becoming hard to start or not starting then you will want to think about adding one. I am not sure what your stereo consists of but if it is just a head unit then 1 hour of not running is NO problem at all.
Jon
Jon
Put your best foot forward!
a battery buddy will click to off when the battery voltage drops below 11 volts (I think). You can press the rest button and have enough juice to start the motor.
just the basic head no amps, havent even stayed out late enough to use the ancore light, I just think it would be over kill but I may be wrong if it doesnt start one day
Charter Member #232
Yup the Battery Buddies work well and they came out with a Marine version last year or the year before. Good choice for the single bat. boat.
Jon
Jon
Don't put the jumper box under the hatch if you have an electric hatch lift as I do, or it won't do you any good. If you can't open the hatch to get the jumper box out, you can't jump start the boat....
