Bye Bye Blowers >
Bye Bye Blowers
Bye Bye Blowers
Old 08-24-2010, 09:00 AM
Originally Posted by Griff
If you go with aluminum heads you might be able to make 600hp on 89 octane with the 540ci/500 Bulldogs that you have. Keep the comp ratio down to around 9.0-9.25 and timing around 32* and make sure to dyno them with 89 octane fuel and watch the AFR's and EGT's.
I thought that 500 Bulldogs already have aluminum heads made by Edelbrock?
Andy is offline
Old 08-24-2010, 09:57 AM
Don't forget the pricey exhaust system. If you already have headers with dry exhaust, 600 hp won't be a problem. Also, n/a 600hp should be easier on the drive since superchargers build (in my opinion) excessive mid range torque. My friend had supercharged engines in his baja, mid range torque was amazing, but always thought his drives were going to blow. He toasted one 3 months later, replaced the drive and sold the boat.
Rexx is offline
Old 08-24-2010, 10:17 AM
Knot 4 Me's Avatar
You are thinking of 525EFI's.
Knot 4 Me is offline
Old 08-24-2010, 12:43 PM
A buddy of mine had bulldogs in his Hustler, when we pulled the engines for a build they had aluminum heads on them. If not stock then someone must of changed them before he bought the boat.
Andy is offline
Old 08-24-2010, 05:12 PM
Yep, I was thinking on the lines of what Ezstriper said. Should be able to get by with 89 octane. Did look at trading them for 525's but have too much money already in them and everything is new so keeping them. Does anyone need a set of perfect blowers for fraction of the cost. let me know have receipts to go with them.
speedchangesyou is offline
Old 08-24-2010, 10:06 PM
Received 1,904 Likes on 957 Posts
They do not have aluminum heads stock.
Griff is offline
Old 08-25-2010, 07:02 AM
birdog's Avatar
What is a 500 bulldog ?.....I have owned 540 Bulldogs...Tall deck mark IV..Rect. port Iron GM heads...
birdog is offline
Old 08-25-2010, 08:47 AM
Get ahold of RM Builder- Bob Mandera! He was talking to me about the bull dog engine and said its easy to get another 250-300 hp out of it.
endeavour32 is offline
Old 08-25-2010, 04:23 PM
PatriYacht's Avatar
They're 540 ci. 700 hp n/a is about it even with the best parts unless you want to spin over 6000 rpm.
PatriYacht is offline
Old 08-25-2010, 06:29 PM
Registered User
bcfountain's Avatar
i also thought the bulldog was a 540.i just thought used a 502 block and bored and strocked to get540,i also heard flat tapplet hydr cam?,,,anybody?
bcfountain is offline
