502 Blues
which crate engine ? these new gen VI engines don't carry much OP have 3 only about 50-60 cold down to 25-30 after running at idle, like others said ck those filter lines, also what filter set up are you running ? what line adapter ? correct restricters in block under filter mount ? try a good filter and 20w50 oil...
Winner on the first guess.. I have been fighting the same issue for 3 years,
I spun mains and it is the same senario, finnally scrapped the block, started freah, dropped it in this weekend, all is good !
![Angry Smiley 038](/forums/images/smilies/angry-smiley-038.gif)
![Drink](/forums/images/smilies/drink.gif)
If these are new Marine crate engines and Gen 6, you have to remove the center pressure relief valve and change the other one to a 30 LBS. Do a search, there has been endless post's on it.
I installed two this spring, and they sing long a song![Drink](/forums/images/smilies/drink.gif)
Here:
http://www.offshoreonly.com/forums/g...-vi-502-a.html
Here:
Here:
Here:
I think Im very lucky----mechanical gauge reads 60 and held for 10 min while on the muffs,going to put back on the water this weekend.. what color is the wire and location of gauge sending unit // what is the wire and location of low oil warning....
