What is the Stock Oil cooler size on a Gen 5 502 MPI?
Looking for the stock size of the oil cooler on a Gen 5 502 MPI. I thought I had measured mine at 3"X18", but i'm being told that is already upgraded. I'll have to go bigger as I can't maintain the oil temps that I'd like (215). Please let me know what the stock size is. Thanks.
Does anyone have any info on the stock cooler size?
2 X 13 http://www.mercruiserparts.com/Show_...ER+AND+ADAPTOR
That should be plenty of oil cooler. Pull it and make sure there isn't any debri in there. Might need bigger oil lines or new thermostat.
I would think if the oil cooling was adequate, I should be able to hold the 210 degree oil temp which is where my oil thermostat opens. I'm measuring temp at the remote filter housing. I usually climb to about 220-230 with wot. If i'm prolonged full throttle I can see 250. At the 230 i'm seeing a little over 40lbs of oil pressure @5000 rpms with 20/50. I'd rather see closer to 50 lbs and getting my oil temps closer to 215 would do that. I'd like to be able to run longer wot with keeping the oil temps cooler which is why i'd like to know the stock size of the cooler. I am also looking into upgrading the block adapter and remote filter housing to get the bigger oil lines so I get more flow.
220-230 is PERFECT. Most guys I know who do dyno work, wont do a pull until the oil temp is around 220. Also 250 is not a problem for modern synthetics. As for pressure, you can try a different oil.
Darrell.
I've been using Brad Penn 20/50 semi synthetic since after break in. Engine has about 60 hrs on it. I know the pressure when hot will go right back up to 50 when the oil temps drop back to around 200. I'd be open to suggestions If someone thinks a different oil would hold more pressure with the heat? I still think it would be a good idea to open up the oil fittings with a different block adapter and filter housing.
I use Amsoil, I am also a dealer, PM me if interested.
I use all 12AN lines and fittings, Canton Racing adaptor on the block. I used the stock merc filter mount but opened up the inside with a rotory tool. There are some real sharp edges that can be removed.
What size are the fittings on the stock filter mount? Did you use AN type fittings on everything?
On the block, be sure you get the 30psi pressure valve on the side, and make sure the center one is removed.
