exhaust manifolds have weird "burn" pattern in them?
What carb and intake is on it and was there a carb adapter to go from a weber holley square bore bolt pattern to the stock gm spread bore if so that is your lean problem it is a
sh!tty set that mercruiser will do to make the cheapest set up to make it run. they did that with all the 330's
well heads are off, cylinders 1 and 8 are the leanest cylinders judging by the combustion chamber. i'm surprised how clean the chambers are for a 500 hour motor, actually everything on this motor is clean clean clean inside. bores look mint, still see nice cross hatching in them/ luckily no surprises have been found!![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
![](http://i246.photobucket.com/albums/gg112/camgsxr1216/baja/IMG_3336.jpg)
Extended tip spark plugs bring spark event closer to piston, similar to timing advance.
Sorry, didn't mean to hijak.
The light color holes do look a bit leaner, but the heads and ports look overall pretty good! By any chance you didn't happen to run a tank of race gas did you? Leaded fuel will give a white/grey color to exhuast when tuned properly.
