top end or complete rebuild, Analise oil?
Be very careful about who you send your stuff to be rebuilt.Auto hot rod shops are not the best place to take your engine. There are many good marine rebuilders who can do the job even if you have to ship away. get good references
There has been many discussions about whether to rebuild or buy a new engine or short block .rebuilding is cheaper but if not done properly will be short lived and may cost you again.That is up to you to decide..... Good luck
Jim
Jim
1 Post
thank for the info. i requested a sample kit from blackstone about a week ago, so as soon as it comes in i will be sending it off to be looked at.
i guess i am going to have the whole engine refreshed. Any idea of what i am looking at cost wise? ballpark of course. anyone know anyone around pittsburgh that can do a marine rebuild?
thanks again
thanks again
I also agree make sure you know who your sending your motor to be rebuilt. I'd recommend Mark Boos@ Precision Marine or Youngs Performance in TN and there's Crockett Marine in Ruby,MI.
If your oil analysis looks good you could just do the crank bearings, rings and a valve job. Yes you can install new crank bearings (rod and mains) without pulling the crank. Just match each shell (std, -.001, etc) exactly as you take them out. You can do rings without pulling the crank. Total cost if you did it yourself would be around $1,000 plus a valve job. That would be with cometic head gaskets and top of the line coated bearings. You could go cheaper, but you shouldn't. If you have the same work done by others, 2x the cost.
BT
BT
i am hoping to just do the crank bearing, rings, and the top end. Anyone know the part number for the isky springs i will need for a 500efi? i have done some reading and it seems that there are two different part numbers for the springs that people are using.
thanks for the help
thanks for the help
Charter Member #1171
id verify oil pressue with a mech guage before I did anything with the bottom end
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Call EDDIE at YOUNG PERFORMANCE MARINE.(16152167449)He will give you some good advice,and try to send you in the rite direction with your rebuild(he is also very fair priced).I had him build me a set of engines last year,and i could not be happier with them,and his service.
LOUIE.
LOUIE.
what state are you in once we know we can give you builders that may be in your area. costs to have a marine motor like yours done keeping it at 500 to 650hp would be 3500 to 6500 from the different guys I have used blower motors are more. art make sure you have the block tanked to get all the oil and water passages cleaned .if you want pm me your area I know a few builders around the country. art
If you are in the Pittsburg area I would suggest: Gellner Engineering Co.
2827 Brookpark Rd.
Cleveland Ohio
44134
Ph. 216-398-8500
Call and talk to Dean ;also look on Face Book!A+++++++rating
That way you can drop the motor off at his place ---- Only a short hop down the turnpike for you..
Jim
2827 Brookpark Rd.
Cleveland Ohio
44134
Ph. 216-398-8500
Jim
