meth injection >
meth injection
meth injection
Old 12-20-2010, 01:04 PM
Default meth injection
Anyone use it on a boat. Looking at possibly adding it as an extra insurance policy for the Procharger. You can have these systems come on at say 3.5 PSI of boost and help with cooling when running wide open. I know the intention of running Meth allows you to run more boost on less octane but is the reason it wont work at lower boost?
kragar is offline
Old 12-20-2010, 01:17 PM
By no means am I an expert on this, but the problem I see with having it come on so early is the quantity of meth you would need. If the engine is tuned to run the meth at say 3 psi, then if you run out, you will have problems. If you have an engine set up to run 8 psi of boost, then it will hit 3 psi pretty easily, not only at wide open. The few guys I know running it go through it pretty quickly. You will need a pretty big tank to run it that much.
Eddie
Young Performance is offline
Old 12-20-2010, 01:21 PM
it will work with lower boost as long as she's tuned for it
u can set them to come on at any level of boost but 3.5 is a bit premature .. call rudy at Ice Injection 302-367-4962
Old 12-20-2010, 02:34 PM
I just pulled 3.5 PSI as an example. Situation is the procharger is set to run 5 PSI on a stock 502 on premium fuel. The idea of adding meth is to compensate for possible fuel quality, help with detonation and increase cooling and act as an insurance policy to the already set system to run at 5 PSI without having the need of Meth. It may be a case that it comes on prgressive at 4 and full at 5 PSI.
kragar is offline
Old 12-20-2010, 03:17 PM
I love the idea of it. Would be nice to set motor up where it can run on pump gas at say 7psi without detonation. Then add the methanol for safety where maybe it comes on at 6psi and above?. I would think just adding methanol to the mix would be worth a few HP from cooling the air charge???? Im sure theres a way to rig up a pressure sensor or something should the pump go out. Similar to a fuel psi sensor or similiar. Tie it into a led light on the dash and a warning buzzer should the methonal system go out. Or maybe IAT gauges?
Maybe use the freshwater tank for methanol? I think my freshwater tank is 20 gallons??
MILD THUNDER is offline
Old 12-20-2010, 04:12 PM
http://www.snowperformance.net/product.php?pk=8
kragar is offline
Old 12-20-2010, 04:34 PM
or just spray water from 4 to 7 and meth from 7 +
methanol eats everything , may want to check out that fresh water tank first .... dont want to spring a leak and have it run to the Bilge they say it burns good
Old 12-20-2010, 04:40 PM
Guys up here just run windsheild washer fluid in their turbo sleds.
kragar is offline
Old 12-20-2010, 04:48 PM
GPM
GPM is offline
Old 12-20-2010, 04:59 PM
turbo sleds
dont compare them to a boat motor we spray 1.5 gallons every 2 mins per motor when them Red lites are on and layin into the boost ..good luck
