Cheap 496 mag upgrades (375hp) >
Old 01-23-2011, 12:37 AM
  #111
Rayler and Dana
I am convinced of the points you have made here and they make total sense to me.
Ok if; a reasonable ground cam; so engine stays together and along with a quality exaust; good stock heads; and computer left very much as is. Is it possible for you to give a basic guide line cam part number list for a few of the popular engines IE 454; 496; 502; 525; Could you give a list for both wet exaust and dry. Or are you saying the stock one's are pretty much maxing everything out? and leave alone if you want things to stay together. Reason is as I understand it; dry exaust allows for hotter cam (reversion thing) and when I have been reading other threads to get an idea of what I should use; the exaust type is not always clear in a given discussion; I have a wet exaust so that is what I am most interested in but maybe there are others with the dry.
With respect to reversion, can you measure the exposure to this, relating only to the grind of the cam? Or would things like, if the engine was a roller setup or not? Fuel inject or not? I know the type of exaust has a lot to do with it as where it mixes. There must be a point where you draw the line as far as cams go and where you say " if you have a wet exaust this: insert part number______ is the hottest cam you should dare to use" Is there a way to simplify the math?
When is the best time to order a cam in so far as a rebuild. What do you need to know? The idea here is starting points so one won't throw away money. The exaust is a no brainer to me. If you soup up a stove it will have to breath and you get a proven high quality exaust. done carry on. The cam is not so easy. In my case I am starting from scratch but I know what some of my peramatures are and I dont need my boat to go 120 mph and blow stuff up all the time. Well maybe I do but a man's got to know his limitations.
as many others, I want to build a solid engine, that will perform, but it can be confusing to find the right recipe that fits a given boat, and a builders expectations. Thats why I am building one! so it is better than the one I have. I dont expect to take a stock 454 short block and slap on a $5000.00 set of Dana's and expect it to gain me 10 mph! That's ridiculous. I understand the props have to be tested but how does one arrive at the engine recipe so the correct parts are got the first time around?
toolsinbox is offline
Old 01-23-2011, 09:33 AM
  #112
Rage's Avatar
Originally Posted by Raylar
We recalibrate PCM555's for the 496 all the time and no we don't pay Mercury for any unlock code as Dustin -USED TO DO? We have our own software and we keep all the Guardian turned on a working after re-programming. We do this programming for Mag to HO upgrades and various Raylar kit packages and engine we specially build.
Best Regards,
Ray @ Raylar
So you do not do custom PCM-555 recalibration for a fee?
Rage is offline
Old 01-23-2011, 09:52 AM
  #113
dana marine products's Avatar
Ray is pretty good on cam talk, so I'll leave that to him.
In regards to proper riser selection to avoid reversion, that's not an easy answer. The rule of thumb is to run the longest riser you can no matter what. In the case of Dana exhaust (which actually goes for $2500) we don't charge extra money for our shorter stainless risers compared to the longer stainless risers.
We usually have to discuss installations case by case to find out exactly how the boat is rigged. The exhaust routing is pretty much different on everyone's boat and usually has different requirements.
In the case of the 496 engine, we were able to make a system that replicates the exact dimensions of the Merc system. This allows an installation no matter what the exhaust routing is. As long as the stock system is on the boat, ours will replace it.
We also do custom tails, which will run extra $$ depending on the complexity of the riser.
An engine is simply a big air pump, the more air it moves, the more air it draws - When a piston starts it's descent on the intake stroke, the exhaust valve is still hanging open a tick - and it pulls vaccum through the exhaust - introduce water to early into the exhaust stream and you've got reversion.
dana marine products is offline
Old 01-23-2011, 02:32 PM
  #114
Wink Trust Those Who Know and Prove Their Worth for Value!
Rage:
We don't do custom remote ECM re-programs because this must be done either on a dyno or in the boat with actual air fuel ratios, knock events monitored and actual power increases measured and confirmed to do a good safe re-program. Kinda close and almost OK re-programs in customized marine high performance engines usually end up with damage and disaster and the small profit from the re-program fee is not worth the reputation and success levels.
As for cams in the 496, why re-invent the wheel and its expense.
Raylar has done over 9 years of cam design, testing and verifyiing on 496's our camshaft profiles and our hundreds of customers can confirm that and speak to our expertise.
Every engine type is different, actual use and applications as well as fuel system types, normal aspiration or supercharged, bore, stroke and cubic inch numbers will determine what camshaft your engine needs. These conditions and specs.all affect the cam grind design and application and no few sizes fill all types and needs.
You are going to spend good money about $400 to $500 for a custom good NEW billet hydraulic roller camshaft for this engine no matter who designs or builds it.
So, if you need a camshaft to work in a 496-8.1L engine for engine power levels, particular performance, reliability and proven results call Raylar and make it easy on yourself, Raylar will get it right!
If you choose to design and spec your own camshafts and experiment on your engines, just keep our toll free number and call us when you need to redo the cam, frustrate yourself with subpar performance or replace parts in the engine when it becomes a basket case!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-23-2011, 03:05 PM
  #115
Rayler
Just 496?
Old 01-23-2011, 08:39 PM
  #116
A couple of questions after reading all this great, and very informative info on 496's
1) I have heard and read several times now that the only difference between the 375hp and the 425hp version of the 496's is the cam and ECM program. I understand by changing these things I can make my original "375" engine put out 425 hp
I seem to remember reading somewhere that the 425hp engines use forged crank and rods, where the 375hp engines use cast crank and rods.
Is this true? and how well will a cast crank engine hold up to the extra hp and rpm's?
Also assuming the cam in the 425 is more aggressive are the springs not also more aggressive? If so wouldn't a spring change also be needed to prevent valve float?
(ok so there were a few questions in there, sorry I am grouping them as one )
2) is the Volvo 496 the exact same internally as the Mercury? I.E. cam specs, compression, cast/forged internals, etc If I got a deal could I use a Merc 425 cam in my Volvo 375 engine or vice/versa?
I assume the basic principles of exhaust would be the same, so can we assume approximately the same returns on an exhaust swap, Volvo-Dana as Merc-Dana ?
And can Raylar or Dustin or anyone else perform the needed changes to the Volvo ECM in order to make these changes?
macjazzy is offline
Old 01-23-2011, 09:05 PM
  #117
Rage's Avatar
[QUOTE=macjazzy;3305501]A couple of questions after reading all this great, and very informative info on 496's
1) I have heard and read several times now that the only difference between the 375hp and the 425hp version of the 496's is the cam and ECM program. I understand by changing these things I can make my original "375" engine put out 425 hp Yes plus the throttle body butterfly plate bleed hole needs to be drilled bigger
I seem to remember reading somewhere that the 425hp engines use forged crank and rods, where the 375hp engines use cast crank and rods.No rods and crank in both are cast but good to ~600hp & rods<<6000rpm
Is this true? and how well will a cast crank engine hold up to the extra hp and rpm's?rods and crank in both are cast but good to ~600hp & rods<<6000rpm
but anything above stock rpm needs valve train upgrade
Also assuming the cam in the 425 is more aggressive are the springs not also more aggressive? NoIf so wouldn't a spring change also be needed to prevent valve float?n/a
2) is the Volvo 496 the exact same internally as the Mercury? I.E. cam specs, compression, cast/forged internals, etc If I got a deal could I use a Merc 425 cam in my Volvo 375 engine or vice/versa?Very likely but not 100% sure. It is my 'understanding' that the base motor is the same but marinization and ECU/harness/sensors are different. Again not for sure.
I assume the basic principles of exhaust would be the same, so can we assume approximately the same returns on an exhaust swap, Volvo-Dana as Merc-Dana ? YesAnd can Raylar or Dustin or anyone else perform the needed changes to the Volvo ECM in order to make these changes?]Duistin could /not sure about Raylar who can speak for himself.[/QUOTE
Response in red above.
Rage is offline
Old 01-23-2011, 09:12 PM
  #118
We recalibrate PCM555's for the 496 all the time and no we don't pay Mercury for any unlock code as Dustin -USED TO DO? We have our own software and we keep all the Guardian turned on a working after re-programming. We do this programming for Mag to HO upgrades and various Raylar kit packages and engine we specially build. We won't re-tune an ECM for a stock engine without modifications for supposed hidden power!
Its Raylar's experience that unless you are upgrading a stock 496-375HP Mag to a 425HP HO or such no reprogramming is really going to make a big difference in a stock 496 . If you bump in a lot of extra timing you will put the cast pistons closer to the edge of detonation and possible damage. We also don't think its wise to up the rpm limit on the HO of 5150rpm on a stock head and valve spring engine as the springs are a bit lite in poundage and a little valve float will also possibly make a BASKET engine assembly!
I am always surprised how many boaters think and equate ECM retuning to extra power like some see in emissions engines in today's vehicles. Most marine OEM engines carry a tune in the ECM that allows the engine to make good reliable power, they are not de-tuned and lazy like a lot of emissions engines in vehicles.
You can push the timing limit and fueling on stock marine engine and sometimes gain 15-30HP but its not significant and the risk to the engine is not really a smart long term move.
ECM retuning is always needed and necessary when moderate to major engine changes are made with cams, heads,compression, cubic inches, etc. Again' there ain't no cheap horsepower in most marine engines, if you find a lot cheap, let me know, I would like to sell It!
Best Regards,
Ray @ Raylar
So Ray are you saying that Merc has licensed you to do these chamges.
Do you have standard programs based on engine mods?
DCB F32 is offline
Old 01-23-2011, 09:16 PM
  #119
Rage's Avatar
Rage:
Best Regards,
Ray @ Raylar
Ray, sounds like a thoughtful & prudent policy to me. Good to hear!
Question, how do you measure/record knock events from a PCM555 ECU?
Rage is offline
Old 01-23-2011, 10:38 PM
  #120
Via the knock sensors.
SDFever is offline
