Water pressure with crossovers/t-stat >
Old 05-22-2002, 06:04 PM
MIKEHTMSR24's Avatar
Originally posted by jdnca1
Mike;
Your point is well taken about low end pressure...it was a concern of mine as well. At idle I have about 4-5 psi, with barely a trickle coming out the dump, at 70 mph pressure is about 15 with a good stream out the dump, and at 100+ pressure is 20. I do know from before I had the dump my idle pressure was exacly the same as now, at 70 I had about 25 psi, and @100+ the guage was buried (I estimate 45psi+) My water temp is 150 all the time, idle..6700rpm, doesn't matter. I run a thermostat in the system as well.
That sounds dialed in to me. I don't have an accurate water pressure gauge on the dash. The one on the intake is though. I'll have to see if mine stays at 18 all the time. I have looked at it at 70 but not high 80's. All of my water dump fittings have a 1" ID.
How is your oil temps. This is something I may have to work on this summer. Will probably need a oil stat.
MIKEHTMSR24 is offline
jryan26
Wanted
1
06-28-2008 10:23 AM
pullmytrigger
14
06-28-2008 06:45 AM
kidapache
Wanted
1
02-21-2008 01:28 PM
VIPER7
29
03-26-2005 12:34 AM
Fuhgedaboudit
28
04-11-2004 02:37 PM
Quick Reply: Water pressure with crossovers/t-stat
