Silent Choice Solenoids? swap them???
Ok I have a 1999 Baja 252, with a 454mag, and it's got the factory silent choice. It works great, BUT I was told some boats have solenoids that are OPEN in the normal position, and when you hit the switch it closes them and some boats are like mine where the normal position is quite, and when I flip the switch, it opens them.
so can I swap them out? is so what's the different part numbers.
I 98% of the time run them open, and every time I start the boat or turn the key for something those solenoids are flipping the exhaust open. would be a lot better if the switch was always off and it was loud, and the ONCE in a blue moon I need it quite I could give them power.
There is only are only 2 ways to do this 1 remove the baffle plate, flip the control arm to the other side, cut the solenoid bracket off the diverter and weld it on the other side then remount and good to go. 2 buy the other type.
Just talked to Corsa, and they say the solenoids are the same its phisically reversed on the pipes. so looks like i can buy the whole backwards diverters, or I can just flip mine like i wan them
