Oil filter housings
I'm looking for 3 oil filter housings like in the photos below. also 1 single and 1 double SS transom mount water pickups. Attached Images. Would anyone have a part number for this?
Those are hp500 thermostats, you will have to run a set of the same if you want your oil temps the same, good idea to replace thermostat inside, they are cheap. bammarine.com has the part number of thermostat housing.....
