Raw Water Pumps
I was wondering if you can split the output on the Jabsco bronze water pumps. Or put a short hose going to a y-pipe to have two supply line of raw water? I want to add a closed water cooling tank and it seems as you would want a separate supply for that. Or you will be cooling your oil, PS and transmission before the closed water cooler.
I know KE makes pumps that already do this but it’s not in the budget.
Ken:
You have to make sure if you split the water you size the orifices to make the right gpm go the right direction. Splitting it up is the best way to cool because you want to maintain the best water to oil cooling differential. But if you don't have the fluid flow to maintain your fluid speed (measured in ft/sec), you'll substantially decrease the efficiency of the coolers you already have and the one you're adding.
All of this is dependent upon the cooler size. as an example, you need about 18gpm minimum for the water side of a 3" cooler.
But note that mercruiser feeds in serial the engine/trans/ps coolers with water and then it heads off to the heat exchanger. So that's not out of the question.
Whatever happened to those chrome plated coolers? :-)
Mr Cool for all of your heat exchangers and oil coolers , transmission coolers and more!
Locations in: Florida, Michigan & Washington!
agreed, it's not necessary, but it would cool better. Without calcs, hard to tell if it would be noticeable.
