Exhaust Dyno Charts
Offshoreonly Advertiser
The standard tails are 6" long. A small piece of rubber exhaust hose connects to the exhaust tips.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
Thank you !
This is great actually, because most correct lengths (when sizing exhaust) call for 12"-20" total length- epending on cid, cam, rpm, and etc. Therefore, the tailpipe can be adjusted to arrive at what the proper length should be for each engine application
I'll find my 502 example (again) so everyone can see what I mean.
Found it:
The following is from inputs I entered on a 502 with 625 or so HP.
Quoting myself from a earlier post
BTW: The program givea much, much more info than I have posted below. But it will give you a good idea on things.
Remember, the 'collector' is not just the headers collector. If risers and tails are same ID, which most re, then they too are part of the collector.
Do not let yourself end up at a worst length collector. It can/will kill performance.
Pipemax
Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
502.176 CID from 3800 to 6300 RPM
--- Single Primary Pipe Specs --- Diameter= 1.899 to 2.024 Length= 33.7 to 36.7 inches long ---
2-Step Primary Pipe Specs ---
1st Dia. inches= 1.899 Length= 16.9 to 18.4
2nd Dia. inches= 2.024 Length= 16.9 to 18.4
--- 3-Step Primary Pipe Specs ---
2nd Dia. inches= 2.024 Length= 8.4 to 9.2
3rd Dia. inches= 2.149 Length= 8.4 to 9.2
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 3.466 to 3.716 Tuned Lengths= 19.4 best and also 9.7 or 38.8
--- Header Collector Specs (Megaphone or Diffuser Cone Shape) ---
Diameter= 2.966 taper to 3.966 Megaphone/Diffuser Length= 19.4 inches
Best HP/TQ Tuned Collector Lengths= 19.4 , 38.8 , 77.6 , 155.2 inches long
Worst HP/TQ Loss Collector Lengths= 29.1 , 58.2 , 116.4 , 232.8 inches long
---- Primary Pipe's Harmonics ----
1st Harmonic = 149.4 inches long ... typically never used
2nd Harmonic = 56.5 inches long ... longest recommended
3rd Harmonic = 33.7 inches long ... highly recommended , best Torque Curve
4th Harmonic = 23.4 inches long ... shortest recommended
5th Harmonic = 17.5 inches long ... typically never used
6th Harmonic = 13.8 inches long ... typically never used
7th Harmonic = 11.1 inches long ... typically never used
8th Harmonic = 9.2 inches long ... typically never used
---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
1st Harmonic = 155.2 inches long ... longest with Mufflers and TailPipes
Note: Worst = 116.4 inches long for HP/TQ Loss
2nd Harmonic = 77.6 inches long ... longest recommended with Mufflers
Note: Worst = 58.2 inches long for HP/TQ Loss
3rd Harmonic = 38.8 inches long ... more bottom-end Torque
Note: Worst = 29.1 inches long for HP/TQ Loss
4th Harmonic = 19.4 inches long ... highly recommended , best Torque Curve
5th Harmonic = 9.7 inches long ... reduced Torque , more top-end HP sometimes
6th Harmonic = 4.9 inches long ... reduced Torque , not recommended
Pipemax
