HP500/500EFI cam grind?
Does anybody know the exact CRANE grind numbers for these 2 cams? A friend lost a lobe on a HP500 cam (2000model) and Merc wants a zillion $$ for a replacement.
Charter Member #30
The HP500 carb cam # is 169611. I can't find my old notes that had the EFI cam but it is different. Call Crane tell them the problem they will ship you a cam for about $230.00 you send them the old one. They are easy to work with.
If you are changing valve springs I would NOT recommend Crane. Try Comp Cams springs or someone else that has normal seat pressures.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
I have Steps & Bubbles!
