Analog Tach reading off
One of my tachs reads off by 500-1000 RPM (low). The Smartcraft displays correct RPM. I've switched tachs and it still reads low on the same side so it's not the tach.
Any thoughts/suggestions? Thanks
I'll check the ground but don't think it's the problem. I also have a Livorsi Data Tach that has dedicated power and ground and shares the tach signal. It also reads the same (low) rpm on the starboard motor.
Something is causing the (analog?) signal to be off on that engine.
Where To
I'd still call Livorsi.
dave
