Boat radio circuit amperage
For those that know off the top of your head, how many amp circuit was your boat's radio on from the factory? TIA!
Ginger or Mary Ann?
Have an JVC HU right in front of me. It has a 10A use on the back. Just reordered a different JVC HU, that one has a 15A fuse. No idea why the difference as they both are same specs.
Thanks. Was going to order something and it stated the head unit had to be on a 15A circuit. Can't get to the boat until this weekend so was curious what most are set up on.
The head unit is not the draw I'm concerened with. I was going to try the Alpine Power Pack which raises the RMS rating from 18W X 4 to 45W X 4. Gets pretty good reviews for the most part but requires the stereo's existing circuit to be 15A or you have to run a separate power/ground wire. If you are going to do that you might as well run a "real" amp. This plugs and plays behind the head unit with no additional wiring needed as long as the existing circuit is 15A or greater.
