Mercury Racing Oil Filter Cross Reference
Any thoughts on the M1-601? It's a crate 502 and I put the Hardin bulkhead on it with the HP6 threads but all of the HP6 filters I've found are 4-5/8" which leaves half the seal unsealed as the bulkhead base is only 4" across. The M1-601 is thinner and should fit nicely.
It does have the internal bypass and I can't figure if that's a good thing or not. The relief valve on the block pad is the heavier mercruiser unit but not blocked off.
1 Post
If you have the room Wix/Napa offer an extra large oil filter for SBC./ BBC engines. It is known as a truck filter, a hair over 8 inches long, more flow and filtering ability. Wix # 51794, Napa Gold 1794, and a racing version is also available from Wix under part # 51794R, but be warned the racing version has a much higher micron rating. While that does allow a slight increase in flow, it also allows slightly larger particles to pass through the filter media. Recommended for racing only with frequent oil and filter changes.
02Formula33ss (02-21-2021)
