Has Anyone Used Gaffrig Performance Sending units with Livorsi Gauges ?
Has anyone used Gaffrig Performance sending units with Gaffrig (Livorsi) Gauges ?
I've got Gaffrig Livorsi Gauges, and got Gaffrig Performance sending units, (oil temp, oil psi, water temp etc) Called the guys at Livorsi, they said they probably wouldn't work, to buy there sending units, the guys at Gaffrig Performance said they'd work no problem.
Has anybody out there mixed and matched this stuff, and got it to work ?
The Livorsi gauges take reverse polarity. So, you can't use a Merc sender with a Gaffrig Livorsi gauge. Call Mark at Bam, tell him what you got, and you'll be doing fine. The fuel pressure sender need to be grounded, for instance. It was a lock up for a few years until the normal hipo guys figured it out. DanL
timucin
10-22-2002 09:01 AM
