Alarm still going off!!!!! Help!!!
Waden54,
Give the factory a call and see if they wired something else into the circuit. Also check the wiring going to the alarm and see if it’s worn and possibly grounding to something.
Dan
Dan
I've checked all the wiring. All is clean. Looks at this point all that's left is to check the ECU for codes and see if a DTC is tripping it. Anybody know where I can get a code reader in Minneapolis? Or, do I have to bring it to a dealer to scan? If it is the ECU, any guess as to the likely culprit???
Wade
Wade
