Rebuild kit for 9780s carburator.
Just wondering if someone knows a number for a rebuild kit that will work for this carb that I can buy in a auto parts store. It is a weber <---(i think no name at least that i found) 9780s carb, it is on a 1997 scarab 22 454
there should ba a metal tag on one of the top screws on carb to identify it. also most kits cover a certain range of carb#s when rebuilding make sure to match the holes on the new gaskets with the old gaskets
![Frown](/forums/images/smilies/frown.gif)
summit racing,,just get the edelbrock marine carb rebuilding kit,,all the parts are the same..
One more question should i just buy a re-manufactured edelbrock 1410 750cfm for $239 or is the carb I got on it now just as good with a good rebuild.
For the rebuild on mine is this the right one to buy
http://www.summitracing.com/parts/EDL-1477/?rtype=10
1 Post
Well the problem I'm having after my last trip out the carb is flooding. If I let it idle for 10 min to warm up then take off it dies out then its hard to start then when I get it cleared out a big amour of black smoke comes out. I changed plugs, plug wires, rotor, cleaned cap, and added a second strike ignition box to help with higher rpm spark. I have a good felling the carb is just not mixing enough air with the fuel. I'm lacking take off power and when cruising at 3000 rpm it sounds like 2 cylinders quit working untill I open it up again it goes away.
1 Post
dont know 750 cfm carb kit is what you need. i think their kit does both 650 and 750
from look at the part brake down it looks the same as the internal parts of the webber..
