ignition timing/super charged
I'm looking for a second opinion on ignition timing specs for a GM 350 engine with a Mercury Thunderbolt IV(v-6) ignition and a roots type supercharger.
What boost, compression, heads, plugs, intercooled or not? Injected or carb?
Here is the set-up:
GM 350 ,162 b&m blower(6-7 pounds of boost),holly 4150 750cfm carb,lunati cam for super charger(custom built for marine use), mercury thunderbolt IV ignition(6-12 degrees timing),standard plugs for mercruiser 260
set your total timing at 34,blower motors like advance even at low rpm,i always use msd distributor and lock it out.
In my opinion 34 is too much with a non intercooled little blower putting out 7 pounds of boost with no knock protection. If it where mine and I was not going to set it up on a dyno it would not have but 30 degrees total as it just not worth the chances.
Allen
Allen
I would set it at 30-32* total. Also I would change the spark plugs to 2 heat ranges cooler.
