cheap prop vs expensive prop
When I wanted to change from a 21" Mirage to somethnig with a lower pitch and smaller blades I searched E-Bay and found a brand new, in thel box, 19" Laser II. Paid 200.00 for a 500.00 prop. It took a little time searching but I found what I wanted.
This place has the thunderbolt for $349 brand new. I assume this is the older style mirage and not the "plus". A mirage plus used is about the same price give or take.
http://www.pbsboatstore.com/quicksil...-propeller.htm
Just bought a (1992 Celebrity 2000 bowrider)
4.3LX
Had a factory 19" prop quicksilver. Picked up, handled outstanding. Only problem was I had low rpm vibrations. I went to a prop dealership and showed them my prop. After discussing my different options I decide to go with an apollo 21" stainless st
My factory prop was stainless steel as well but a 19" and a solid hub.
(Output from this prop is 45mph-4800rpm. Steering is solid and very responsive in excel ing.)
This new apollo is stainless steel 21" removable hub
(This prop gave me terrible results.. I was interested in more speed. 4200rpm-40mph. And that was with a full load. So I decide to cut the load in half and see how it handled. Same results.
I am returning the prop tomorrow and possibly going with the Mirage Thunderbolt. Any suggestions?
I want to keep great control, handleing and hole shot. I was only trying to get more speed. But after testing out this apollo prop I am not knowing what to do. I don't want to play this prop game.
I've done some looking on line about the prop I am using now and it seams that this prop is not made anymore. But it was with the Mirage line up. So my thinking is if I get the thunderbolt prop with the same pitch as my current prop will it give me the same results? Is there a difference in prop performance from solid hub or removable hub design.
4.3LX
You might try adding a little cup to the tips of your 19p, sounds like 21p is too much prop. Labbing what you have might give you the results your looking for. With all stock engine & drive your limited in what you can do. Brett & Brad @ BBlades are good people, give them a call. Randy
