Camshaft for 350
I ran twin TP 174s (from memory) years ago before going to the HOT roller cam and fast burn heads. Close to Artics suggestion....typically described as an "RV cam" in the books.. .457 lift int & exh, .269/.269 /112
Used stock exhaust and corvette Al heads with 1.94 valves.
peak 357 HP at 5500, 341 ftlbs...according to GM (crate motor)...
Lane
Lane
I am in the process of replacing the 350/260 engine in my scorpion 230. The engine I am replacing it with was built by a local machine shop, I was told it would have a conservative 350+ hp.(@ 5000RPM) I was just wondering on your take on it. The engine has 9:1 compression 4 bolt stock bottom, (heads) 2.02/1.60 valves with 3 angle blended bowls unshrouded valves and a 30 deg. backcut on valves, cleaned up runners, gasket matched and pinned studs. Weiend stealth air gap intake ( has roughed up runners for better fuel atomization) gasket matched with 2 inch spacer and a holley 600 spread bore carb with stub stack. The cam specs are 262/272 adv duration, 204/214 @ .050, lift 420/442 and a lobe seperation of 112. Stock omc exhaust (for now) with warmed over and smoothed runners and thru hulls. I am concerned with cam. Is it enough to get me to the 350+ hp mark and with a ls of 112 will this give me probs. with water reversion. A lot of the cams I read about are at 114. Any input would be greatly appreciated. Thanks
112 ls should be fine with that cam and exhaust but it may be good to increase the idle speed just a bit to insure against reversion
I would recommend a Comp Cams XM270HR paired with the vortices which would put you around that HP.
What type of cyl heads are do you have? Vortecs 12558060 - SD8060A would be the way to go.
Heres what Comp Cams says about their Extreme Marine Cams.....
Comp Cams 'Xtreme Marine' Hydraulic Flat Tappet Camshafts
A Unique Cam for Marine Applications
If you're heading to the great outdoors, Comp Cams offers camshafts designed specifically for marine applications where low idle speeds are necessary and where restrictive exhausts require special cams that work well against wet exhaust system back pressure. These unique camshafts generate an extremely wide powerband, offering the low-end torque needed to jerk skiers up quickly and the high-end power needed for maximum performance. Also, Comp's larger camshafts are engineered for engines with less restrictive exhausts and drives that will tolerate higher idle speeds. An excellent choice for jet boats or power boats.
heres the list.....from the Jeg's catalouge
Chevy 262-400ci Small Block 1955-98
249-12-232-3
Xtreme Marine™ Hydraulic Flat Tappet Camshaft
Lift .447/.462
Duration 256/262
RPM Range 1000-5000
More info on Comp Cams 12-232-3
$129.99
Ships
in 6 days
249-12-236-3
Xtreme Marine XM262H Hydraulic Flat Tappet Camshaft Only
Lift: .462''/.477''
Duration: 262°/268°
RPM Range: 1300-5500
More info on Comp Cams 12-236-3
$129.99
Ships
in 6 days
249-12-240-4
Lift .480"/.489"
Duration 270/286
RPM Range 1600-5800
More info on Comp Cams 12-240-4
$139.99
Ships
in 6 days
249-12-244-4
Lift .498"/.500"
Duration 278/292
RPM Range 2000-6200
More info on Comp Cams 12-244-4
$139.99
Ships
in 6 days
249-12-248-4
Lift .516"/.522"
Duration 290/306
RPM Range 2500-6500
More info on Comp Cams 12-248-4
$139.99
Ships
in 6 days
249-12-318-4
COMP Cams Xtreme Marine Hydraulic Flat Camshaft
Lift .464"/.464"
Duration 268/276
RPM Range 2400-5400
More info on Comp Cams 12-318-4
$139.99
Ships
in 6 days
249-12-324-4
Lift .483"/.483"
Duration 280/280
RPM Range 2600-5700
More info on Comp Cams 12-324-4
$139.99
Ships
in 6 days
249-CL12-232-3
Xtreme Marine XM256H Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .447''/.462''
Duration: 256°/262°
RPM Range: 1000-5000
More info on Comp Cams CL12-232-3
$199.99
Ships
Today
249-CL12-236-3
Xtreme Marine XM262H Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .462''/.477''
Duration: 262°/268°
More info on Comp Cams CL12-236-3
$199.99
Ships
Today
249-CL12-240-4
Xtreme Marine XM270H Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .480''/.489''
Duration: 270°/286°
RPM Range: 1600-5800
More info on Comp Cams CL12-240-4
$205.99
Ships
in 6 days
249-CL12-244-4
Xtreme Marine XM278H Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .498''/.500''
Duration: 278°/292°
RPM Range: 2000-6200
More info on Comp Cams CL12-244-4
$205.99
Ships
in 6 days
249-SK12-232-3
Xtreme Marine™ 256H Hydraulic Flat Tappet Camshaft Small Kit
Lift: .447/.462
Duration: 256/262
More info on Comp Cams SK12-232-3
$225.99
Ships
in 6 days
249-SK12-236-3
Xtreme Marine XM262H Hydraulic Flat Tappet Small Kit
Lift: .462''/.477''
Duration: 262°/268°
More info on Comp Cams SK12-236-3
$225.99
Ships
in 6 days
249-SK12-240-4
Xtreme Marine XM270H Hydraulic Flat Tappet Camshaft Small Kit
Lift: .480''/.489''
Duration: 270°/286°
More info on Comp Cams SK12-240-4
$229.99
Ships
in 6 days
249-SK12-244-4
Xtreme Marine XM278H Hydraulic Flat Tappet Camshaft Small Kit
Lift: .498''/.500''
Duration: 278°/292°
More info on Comp Cams SK12-244-4
$229.99
Ships
in 6 days
249-SK12-248-4
Xtreme Marine™ XM290H Hydraulic Flat Tappet Camshaft Small Kit
Lift: .516"/.522"
Duration: 290/306
RPM Range: 2500-6500
More info on Comp Cams SK12-248-4
$232.99
249-12-232-3
Lift .447/.462
Duration 256/262
RPM Range 1000-5000
$129.99
Ships
in 6 days
249-12-236-3
Lift: .462''/.477''
Duration: 262°/268°
$129.99
Ships
in 6 days
249-12-240-4
Lift .480"/.489"
Duration 270/286
RPM Range 1600-5800
$139.99
Ships
in 6 days
249-12-244-4
Lift .498"/.500"
Duration 278/292
RPM Range 2000-6200
$139.99
Ships
in 6 days
249-12-248-4
Lift .516"/.522"
Duration 290/306
RPM Range 2500-6500
$139.99
Ships
in 6 days
249-12-318-4
Lift .464"/.464"
Duration 268/276
RPM Range 2400-5400
$139.99
Ships
in 6 days
249-12-324-4
Lift .483"/.483"
Duration 280/280
RPM Range 2600-5700
$139.99
Ships
in 6 days
249-CL12-232-3
Lift: .447''/.462''
Duration: 256°/262°
$199.99
Ships
Today
249-CL12-236-3
Lift: .462''/.477''
Duration: 262°/268°
$199.99
Ships
Today
249-CL12-240-4
Lift: .480''/.489''
Duration: 270°/286°
$205.99
Ships
in 6 days
249-CL12-244-4
Lift: .498''/.500''
Duration: 278°/292°
$205.99
Ships
in 6 days
249-SK12-232-3
Lift: .447/.462
Duration: 256/262
$225.99
Ships
in 6 days
249-SK12-236-3
Lift: .462''/.477''
Duration: 262°/268°
$225.99
Ships
in 6 days
249-SK12-240-4
Lift: .480''/.489''
Duration: 270°/286°
$229.99
Ships
in 6 days
249-SK12-244-4
Lift: .498''/.500''
Duration: 278°/292°
$229.99
Ships
in 6 days
249-SK12-248-4
Lift: .516"/.522"
Duration: 290/306
$232.99
They are wrong. Sorry.
As DMoore suggested 218/224 at .050" with 112LSA , and another person on the HotCam (218,228) , will get you close or just over depending on the heads used.
These (Comp Cams + GM Hot Cam) have been run in tons of marine small blocks and believe it or not they stop pulling at 5200rpm on 5.7's.
Fact, not theory.
As mentioned, Bob Madera is a great resource + cam supplier to help you get to your goals.
Fact, not theory.
So over the weekend I was looking for a set of vortec heads and came across a vortec long block which I ended up purchasing from a friend. I am just going to shelve the other motor. It is a fresh motor with flat tops and it is suppose to be 9.2:1 compression eith the stock roller cam setup. So now my question is, I would like to obtain between 350- 400 hp. Is it possible and what cam, intake and exhaust to run. I would like to keep the roller setup and have plans to upgrade the exhaust. I appreciate all the responses and am learning a lot about .
Intake. edelbrock RPM Air Gap
Camshaft Comp Cams XM270 HR
Exhaust. Dana, Stainless Marine or if on budget GLM Aluminium.
Make sure at minimum that good rod bolts (ARP) are used for higher RPMs.
Yes this combo should put HP approx 350HP but not much more.
If mor power is needed you may want to go with 383 rotating assembly.
Just my opinion THX
350 horsepower is doable (on pump gas) but you will need to twist the engine at least to 5200-5500 rpm. 400 horsepower is doable (on pump gas) but you will need to twist the engine to 5700-5900 rpm.
You will need a camshaft that works at high rpm but will give up a little torque at low rpm.
Are you prepared for the increased noise of your engine at the higher rpm?
The reduction of torque at low engine speeds?
How about the extra noise of thru-the-transom exhaust?
Most people have an unrealistic idea about a pump gas 350making 400 horsepower at 4800 rpm. The only way that happens is with a supercharger and premium fuel.
By all means modify the engine for more performance but set your goals a little lower. 325 horsepower @ 5000 rpm is very doable with a 350 on pump gas.
Dennis Moore
Dennis Moore
